10-Jun-2020 09:16
Hello All,
Requesting help to understand below iRules.
1) iRule-1
# save hostname for use in response
set fqdn_name [HTTP::host]
when HTTP_RESPONSE {
if { [HTTP::is_redirect] }{
if { [HTTP::header Location] starts_with "/" }{
HTTP::header replace Location "https://$fqdn_name[HTTP::header Location]"
HTTP::header replace Location "[string map {{http://} {https://}} [HTTP::header Location]]"
2) iRule-2
when CLIENT_ACCEPTED {
if {[matchclass [IP::client_addr] equals $::ins-prod-xyz_class]} {
snatpool xyz_prod_snatpool
3) iRule-3
priority 0
when HTTP_REQUEST { if { [class match [string tolower [HTTP::header "User-Agent"]] contains undesired_agents_class ] } { drop } }
4) iRule-4
if { [string tolower [HTTP::host]] equals "learn.x1y2z3.com" } {
HTTP::respond 301 Location "https://www.abc.com/health-learn/quote/"
10-Jun-2020 10:32
First, let's know about events:
HTTP_REQUEST:
An iRule event triggered when the system fully parses the complete client HTTP request headers (that is, the method, URI, version, and all headers, not including the HTTP request body).
HTTP_RESPONSE:
An iRule event triggered when the system parses all of the response status and header lines from the server response.
Note: HTTP_RESPONSE is specific to a server response passing through the load balancer, and is not triggered for locally-generated responses (e.g. sent using the HTTP::respond command)
CLIENT_ACCEPTED:
An iRule event triggered when a client has established a connection.
Complete documentation for all commands, see:
https://clouddocs.f5.com/api/irules/
Rule #1:
# When client send a HTTP request
#Stores a variable with FQDN hostname (and port when explicit) from host header during client request.
# e.g.
# HTTP request header
# GET /path/page?param=value HTTP/1.1
# Host: www.mysite.com
# User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.97 Safari/537.36
# Accept: */*
# fqdn_name = www.mysite.com
# When server respond that HTTP request
# Check if the server response is a redirection to another location
# e.g.
# HTTP/1.1 302 Found
# Location: /login
# Connection: Keep-Alive
# Content-Length: 0
# If Location header starts with "/", means that you were implicited redirected to a resource on same FQDN and protocol.
# e.g.
# Location: /login (Implicit location http://www.mysite.com/login)
# Location: http://www.mysite.com/login (Explicit location)
# Rewrite Location header to redirect to https protocol and fqdn stored on variable plus location address before send response to client
# e.g.
# Location: /login - rewrite to - Location: https://www.mysite.com/login
# Else, rewrite/replace protocol http to https on that location
# e.g.
# Location: http://www.mysite.com/login - rewrite to - https://www.mysite.com/login
# Location: https://www.mysite.com/login - nothing to match or do
Rule #2:
# When client is connected to VS
# Check that the client's IP matches a record within data group wich name is stored in the static variable: $::ins-prod-xyz_class
if { [matchclass [IP::client_addr] equals $::ins-prod-xyz_class] } {
# If so, do a source address translation with addresses within a snat pool
Rule #3:
# Set order to be first on execution
# If you have multiple rules attached in VS, it should be the first request event to run
# https://clouddocs.f5.com/api/irules/priority.html
priority 0
# Drop requests when user-agent/client browser is in a blacklist stored in datagroup
drop
Rule #4:
# if host is learn.x1y2z3.com, then send HTTP 301 to redirect to that location
# HTTP 301 = Moved Permanently
Is it clear? I hope it helps.
Regards
10-Jun-2020 11:22
Hi CJ,
This is perfect, will spend some more time on your reply and back to you/forum in case of any query.
Well...sorry but i missed to add 02 more iRules in my prior post,
5) iRule-5
set app_pool [class match -value -- [string tolower [HTTP::uri]] starts_with services_produat_redirect_class]
if {$app_pool ne ""} {
pool $app_pool
pool abc_uat_pool1
Here : what is this service "services_produat_redirect_class" , Is this a custom one or pre-defined one...if custom then..where should i find and check from GUI that what all configuration has been defined under this service.
6) iRule-6
set app_pool [class match -value -- [string tolower [HTTP::uri]] starts_with services_redirect_class_8085]
pool $app_pool
return
Here : what is this service "services_redirect_class_8085" , Same query as in iRule-5...Is this a custom one or pre-defined one...if custom then...where should i find and check from GUI that what all configuration has been defined under this service.
10-Jun-2020 11:50
These data groups are custom defined. You find all ltm data groups on menu:
Local Traffic >> iRules >> Data Group List
The rules are searching for a pool name based on URI on within dg, then if found (not equals empty), request are send to this pool name, otherwise return or send to a default pool.
Regards.
10-Jun-2020 12:04
So here by "$app_pool" meaning a default pool only.
10-Jun-2020 12:18
Not exactly, this variable is the result from "class match" that search for pool name based on URI, so, it's default for that uri.
Think the default pool for all rest would be the "abc_uat_pool1" on rule #5 and for rule #6 some predefined pool, as a default pool set on virtual server.
Regards.
22-Jun-2020 08:55
Hello CJ,
Could you please explore more on below iRule :
pool $app_pool
return
As per your previous reply, I understand...that the rules are searching for a pool name based on URI OR within Data Group, If found (not equals empty), request are send to this pool name, otherwise return... (but return to where ...back to search criteria..?)
23-Jun-2020 09:17
Hello,
The "return" command tells to exit/break from event HTTP_REQUEST. In your iRule the return looks disposable since it don't have code to escape after "return".
Example when return could be useful:
If { condition 1 matches } {
Do something here
} Else {
return
# This and lines below are reacheable only if condition 1 above is met
If { condition 2 matches } {
Do something here
Do something here
and on
Regards
