Technical Forum
Need help on configuring new VIP , new pool and nodes in CLI
chethan_181144
Hi Team ,
Need help on configuring new VIP , New Pool and Nodes in CLI , Please help me with the command . VIP ip details and name is given below ,
Sys::Version Main Package Product BIG-IP Version 11.5.3
VIP to be created on bigipqa:
172.22.167.129:1433 --> ICA-DLBSQL-NTCS-INT-1433
Load Balancing Method=roundrobin Nodes: 172.16.231.84:1433 172.16.231.85:1433 Persistence=none Monitor=tcp
2 REPLIES 2
Salim_83682
Historic F5 Account
You need to use the TMOS shell (tmsh) to create such objects. For example, the following command will create a LTM pool:
tmsh create ltm pool members add { 172.16.231.84:1433 172.16.231.85:1433 } monitor tcp
Please refer to the tmsh documentation online:
https://support.f5.com/content/kb/en-us/products/big-ip_ltm/manuals/product/bigip-tmsh-11-5-0/_jcr_content/pdfAttach/download/file.res/bigip-tmsh-11-5-0.pdf
You can also use the built-in help ('?','help') and autocompletion feature ('tab') within tmsh.
Salim
Jinshu
Cirrus
Cirrus
  1. Create pool
tmsh create ltm pool ICA-DLBSQL-NTCS-INT_POOL members add { 172.16.231.84:1433 172.16.231.85:1433 } monitor tcp
  1. Create Virtual Server
tmsh create /ltm virtual ICA-DLBSQL-NTCS-INT-1433 source 0.0.0.0/0 destination 172.22.167.129:1433 pool ICA-DLBSQL-NTCS-INT_POOL
Please read below guide if you would like to do more modifications.
https://support.f5.com/content/kb/en-us/products/big-ip_ltm/manuals/product/bigip-tmsh-11-5-0/_jcr_c...
-Jinshu
