Technical Forum
Need help in creating a monitor
Shoaib_020
Hello All,
I got a requirement to create a monitor to check the health of a host.
Type the REST API command GET https://IP_Address:443/xxx.yyy
the response would be - HTTP/1.1 200 OK
Please let me know what would be the format of send and receive string.
1 REPLY 1
boneyard
MVP
MVP
have you already tried yourself? there is lots of information on this available if you search, i would advise you to look at that and then try or show what you think it should be
start here and follow the links:
https://devcentral.f5.com/s/question/0D51T00006kH8mK/send-and-receive-string-explanation-in-a-http-monitor
