Technical Forum
Need help for an iRule to rewrite the URI value and drop the session which is not matching the URI
Thiyagu
Cirrus
Cirrus
Hello All,
I'm in need of help for an iRule to rewrite the URI value and drop the sessions which are not matching the URI value. I have prepared the below the irule and I would like whether the below work as expected
Could you please share your ideas
   if {[string tolower [HTTP::uri]] starts_with "/test1"}{
       set newuri [string map -nocase {"/test1" "/test2/abc"} [HTTP::uri]]
       HTTP::uri $newuri
       pool POOL_TEST
           else {
                drop
Regards,
Thiyagu
1 REPLY 1
SanjayP
MVP
MVP
should work. Are you having any issue in particular with this?
