13-Jul-2022 10:41
13-Jul-2022 16:45
You might have some work to do if you have multiple services and different service status strings, but something like this might work for you:
ltm monitor http test.http {
adaptive disabled
defaults-from http
interval 5
ip-dscp 0
recv "Service Status: UP.*Service Name:Gen2_EPL"
recv-disable none
send "GET /\r\n"
time-until-up 0
timeout 16
19-Jul-2022 07:05
@bep6vaku - If your post was solved it would be helpful to the community if you selected *Accept As Solution* on the relevant reply (or replies). This helps future readers find answers more quickly and confirms the efforts of those who helped.
Thanks for being part of our community.
Lief
