03-Feb-2021 08:48
I´ve an Irule that scans for two expressions, supportportalen-test and web02 and adds a full FQDN instead of the shortname.
# Explicitly disable the stream profile for each request so it doesn’t stay
# enabled for subsequent HTTP requests on the same TCP connection.
STREAM::disable
HTTP::header remove "Accept-Encoding"
when HTTP_RESPONSE {
# Apply stream profile against text responses from the application
if { [HTTP::header value Content-Type] contains "text"} {
STREAM::expression {@http://supportportalen-test/@http://supportportalen-test.hej.se/@@http://web02/@http:/web02.hej.se/@}
# Enable the stream profile
STREAM::enable
My issue are that the Irule only adds the full FQDN on supportportalen-test but not on web02.
I found this https://devcentral.f5.com/s/articles/ltm-stream-profile-multiple-replacements--regular-expressions the syntax on the stream expression in the link seems to be correct but it still not works.
Any takes?
//Mikael
Solved! Go to Solution.
04-Feb-2021 01:55
Hi Mikael,
STREAM::expression [list { @http://supportportalen-test/@http://supportportalen-test.hej.se/@ } { @http://web02/@http:/web02.hej.se/@ }]
https://clouddocs.f5.com/api/irules/STREAM__expression.html
04-Feb-2021 01:55
Hi Mikael,
05-Feb-2021 02:00
Yes, your code worked with a slight modification. I had to remove the spaces between
"{ @" and "@ }"
From your link.
Note that the stream-expression string must not begin or end with blank space. Erroneous spaces will not provoke error messages but will prevent matching any data.
But thanks for your help.
//Mikael
