Maintenance page without doing SSL bridging and using HTTP profile
I am trying to host a maintenance page on f5 itself using iFiles but I have been told that I have to do SSL bridging as I am using HTTP profile with the iRule to trigger the maintenance page via iFiles. The problem is our business require traffic to be end to end encrypted for that I am using performanceL4 and after that I am not able to host maintenence page on f5 using iFiles as if I use http profile with perfomanceL4 then it breaks the connection. Is there a way that can be used to host a maintenence page on f5 using iFile. Or the second option we can use an external portal and redirect all packets to that portal without doing SSL bridging. ???
may this be usable?
// config [root@ve13a:Active:In Sync] config tmsh list ltm virtual bar ltm virtual bar { destination 172.28.24.10:443 mask 255.255.255.255 pool foo profiles { fastL4 { } } rules { qux } source 0.0.0.0/0 source-address-translation { type automap } translate-address enabled translate-port enabled vs-index 13 } [root@ve13a:Active:In Sync] config tmsh list ltm pool foo ltm pool foo { members { 200.200.200.101:443 { address 200.200.200.101 session monitor-enabled state down } } monitor fake } [root@ve13a:Active:In Sync] config tmsh list ltm rule qux ltm rule qux { when CLIENT_ACCEPTED { if { [active_members [LB::server pool]] < 1 } { virtual sorrypage } } } [root@ve13a:Active:In Sync] config tmsh list ltm virtual sorrypage ltm virtual sorrypage { destination 0.0.0.0:443 ip-protocol tcp mask any profiles { clientssl { context clientside } http { } tcp { } } rules { sorrypage_rule } source 0.0.0.0/0 translate-address disabled translate-port enabled vlans-enabled vs-index 14 } [root@ve13a:Active:In Sync] config tmsh list ltm rule sorrypage_rule ltm rule sorrypage_rule { when HTTP_REQUEST { HTTP::respond 200 content "this is sorry page\n" noserver } } // test [root@centos1 ~] curl -ik https://172.28.24.10 HTTP/1.0 200 OK Connection: Keep-Alive Content-Length: 19 this is sorry page
- Macaron
Thanks, I see you used when HTTP_REQUEST event in your iRule. The problem is if use this event, than I must have to use HTTP profile with VS which will intern not trigger maintenance page without doing ssl bridging.
The second option I can utilize is hosting maintenance page on an external server and route traffic to that server in case the VS goes down. Not sure if it is possible without SSL bridging.?
I see you used when HTTP_REQUEST event in your iRule. The problem is if use this event that I must have to use HTTP profile with VS which will intern not trigger maintenance page without doing ssl bridging.
there are 2 virtual servers, aren't there? the http profile is in the internal virtual server (i.e. not the external one which is facing users).
- Macaron
Worked perfectly fine !!! Thank you
- nitass_89166
Noctilucent
may this be usable?
- Macaron
- nitass_89166
Noctilucent
- Macaron
