Technical Forum
Custom Alert Banner
Move from /PartitionA to /Common
JoeReid
My customer has a 3600 running 12.1.2, and wants to move their /PartitionA to /Common. Is there an easy way to do this, or will it necessitate the rebuilding of the F5 from scratch?
1 REPLY 1
wlopez
Cirrocumulus
Cirrocumulus
All shared/synchronized objects created under /PartitionA should be included on "/config/partitions/PartitionA/bigip.conf".
Depending on how big a list of objects(virtual servers, pools, profiles, iRules, etc.) are in that file, it could be as simple as:
Copying those into a text editor
Replacing "/PartitionA" with "/Common"
Edit "/config/bigip.conf" (make a copy or download before editing) by inserting the edited additional objects from "/config/partitions/PartitionA/bigip.conf"
Validate the edited configuration file (tmsh load sys config verify)
Correct any errors from the previous validation step
Load the edited configuration file (tmsh load sys config)
Hope that helps.
