12-Sep-2022 20:20
Hi F5 community,
Can F5 system capable to send email notifications alert if CPU and Memory is more than 80%?
We tried to check in user_alert.conf and alert.conf we don't see any description.
May we know what did you do on your side to provide this requirement? Thanks in advance.
13-Sep-2022 00:15 - edited 13-Sep-2022 00:23
Hi T0nyP,
Yes, it's possible with a custom alert in user_alert.conf, check this K article below :
https://support.f5.com/csp/article/K3667
You can check the log message send in case of high CPU Usage in /etc/alertd/alert.conf
[root@f5Bigip:Active:In Sync] config # cat /etc/alertd/alert.conf | grep CPU
alert BIGIP_SYSTEM_CHECK_E_CPU_TEMP_HIGH {
lcdwarn description="CPU Temp too high." priority="3"
alert BIGIP_SYSTEM_CHECK_E_AOM_CPU_TEMP_HIGH "Air Temperature near .*? Host.*? is too high .*?" {
lcdwarn description="Air temperature near host CPU is too high" priority="3"
If you use ASM/AWAF module, you can monitor Total CPU Usage with ASM alerts :
https://techdocs.f5.com/en-us/bigip-14-1-0/big-ip-asm-implementations-14-1-0/monitoring-asm-system-r...
Regards
13-Sep-2022 01:10
Hi @Lidev ,
Thanks for replying and Apology. I think my question is not clear.
What we would like to know is about the CPU Utilizations and Memory Utilizations if more than 80%?
Not on the environmental temperature heat value of the appliance.
13-Sep-2022 01:22
All you need to know about CPU and Memory usage on F5 BIG-IP is describe on these KB :
K05372587: BIG-IP performance check-list
K71764661: Understanding BIG-IP CPU usage
