09-Aug-2023 07:30
Hi community.
I have been trying to work out the best way to check my Wide-IP configuration is consistent across multiple LTMs.
I have a WIP, that contains a pool, that contains 2 LTM VIPs in 2 DCs - how can I be sure that services in the LTM VIPs are consistent?
For example, LTM-1 in DC-1 has a VIP containing a pool of 2 servers listening on https.
LTM-2 in DC-2 has the same pool of 2 servers listening on https – all good so far.
Engineer adds new server to DC-1 LTM-1 pool but doesn’t add the same server to DC-2 LTM-2.
I now have inconsistent services across the 2 DCs.
Has anyone scripted anything to check each WIP/pool for LTM VIPs then checked each of the configured LTM VIPs for pools/services and report on differences?
Thanks in advance.
09-Aug-2023 21:23
@mlwebster I am not aware of a way to force the GTM to check consistency amongs VSs on the LTMs. This might have to be one of those situations where you have a runbook that specifies when messing with X make sure you do the exact same change on Y. If you had a BIG-IQ it would make it slightly easier to validate but still would be manual. You might consider automation to add in new pool members to both destination LTMs in question.
10-Aug-2023 00:19
@Paulius thanks for the feedback. I do have a BIG-IQ but take your point that it is still a manual process.
I'm happier with new VSs on LTM as they are largely automated, its more tweaks and changes to existing VSs where my concern comes from - we all forget to check things every now and again.
28-Aug-2023 14:09
@mlwebster - If your post was solved it would be helpful to the community to select *Accept As Solution*.
Thanks for being part of our community.
