17-Aug-2023 01:39
I've created an iCall script from TMSH, but now I have to modify it. Creating a script from TMSH is fine, no problem, but modifying is a bit more troublesome.
(tmos)# modify /sys icall script myscript
Syntax Error: one or more properties must be specified
(tmos)# modify /sys icall script myscript definition
Syntax Error: the script "definition" must be enclosed in { }
I was hoping that the script would open in an editor like it does when you run "create /sys icall script".
Which method is the best way to create and modify scripts?
/eljay
Solved! Go to Solution.
17-Aug-2023 02:05
17-Aug-2023 02:05
edit /sys icall script myscript
17-Aug-2023 02:17
That easy?! 🙈 Thanks a lot, @PeteWhite!
