Technical Forum
Modify XML POST request
David_T
I need to change some values in an XML Post REQUEST to Sharepoint (search) as it embeds URL in the XML with https: and I need it to be http.
I was looking to use STREAM::EXPRESSION which I am successfully using for doing a similar replacement in the RESPONSE.
This is what I thought would work:
  # Explicitly disable the stream profile for each client-side request so it doesn't stay
  #  enabled for subsequent HTTP requests on the same TCP connection.
  STREAM::disable
# The line below prevents the server from compressing its responses.
  HTTP::header remove "Accept-Encoding"
  # Apply stream profile against text responses from the application
if { [HTTP::method] eq "POST" } {
HTTP::collect
  set ispost 1
when HTTP_REQUEST_DATA {
  if { [HTTP::header value Content-Type] contains "text"} {
#replace https with http
STREAM::expression "@https://@http://@"
# enable the stream filter for this request only
STREAM::enable
//recalculate the content-length after the replacement
if { [info exists ispost] } {
HTTP::header insert Content-Length [HTTP::payload length]
But I am getting an HTTP 411 response from the backend (which I had thought recalculating the content-length header would fix).
Any pointers would be appreciated.
Regards,
David.
2 REPLIES 2
PeteWhite
F5 Employee
F5 Employee
Don't use HTTP::header insert - then you'll get two Content-Length headers. Just check that there is already one present and update it. If it is not present then insert it
if { [HTTP::header exists Content-Length] } { HTTP::header replace Content-Length $contentLength } else { HTTP::header insert Conent-Length $contentLength }
Thanks Peter.
After a lot of experimentation I came to the conclusion that using Stream for request processing just doesn't work - which may explain there are zilch examples I could find.
Anyway I achieved what I wanted with the below:
when HTTP_REQUEST { # Explicitly disable the stream profile for each client-side request so it doesn't stay # enabled for subsequent HTTP requests on the same TCP connection. STREAM::disable   # The line below prevents the server from compressing its responses. HTTP::header remove "Accept-Encoding" # Apply stream profile against text responses from the application if { [HTTP::header value Content-Type] contains "text"} { HTTP::collect [HTTP::header Content-Length] set clen [HTTP::header Content-Length] } }   when HTTP_REQUEST_DATA { regsub -all "https://mysite" [HTTP::payload] "http://mysite" newdata HTTP::payload replace 0 $clen $newdata HTTP::release }   when HTTP_RESPONSE { # Explicitly disable the stream profile for each server-side response so it doesn't stay # enabled for subsequent HTTP responses on the same TCP connection. STREAM::disable if { !([HTTP::header exists "Strict-Transport-Security"])} { HTTP::header insert "Strict-Transport-Security" "maxage=16070400; includeSubdomains" }   # Apply stream profile against text responses from the application if { [HTTP::header value Content-Type] contains "text"} { # Look for the http:// and replace it with https:// STREAM::expression {@http:@https:@ @//mysite/@//mysite.example/@} # Enable the stream profile for this response only STREAM::enable } }
