Technical Forum
mirroring on diferent firmware version
Mario_Franco
Altostratus
Altostratus
Hello everyone,
I've implemented mirroring on several VS's that needed it, but now I need to upgrade and I don't see any info on whether mirroring works on a different version.
I know I need to disable mirroring before upgrading, but if I enable it after upgrading the first bigip, will mirroring work?
ex. bigip1 active, bigip2 standby -> I disable mirroring -> update bigip2 -> re-enable mirroring.
Now bigip1 on V15.X and bigip2 on V16.X could mirroring work?
2 REPLIES 2
oscarnet
Altocumulus
Altocumulus
HI :
When only the mirroring with Active is set to enable, it will not be able to accept mirror traffic on Standby.
So, mirroring in not work.
https://support.f5.com/csp/article/K84303332
Have a good day!
Hello @Mario_Franco,
Mirroring feature was changing many times since it was created, so the compatibility between major releases is not officially supported.
Important: Connection and persistence mirroring will not function properly if the BIG-IP systems in a high-availability pair run BIG-IP versions with different mirroring transport protocols. For example, standard upgrade procedure calls for upgrading one system in the high-availability pair while the peer system temporarily runs the older version. However, if you use an upgrade path where the systems in the high-availability pair are running BIG-IP versions with different mirroring transport protocols, mirroring will not function during this time.
https://support.f5.com/csp/article/K7225
Despite of this, mirroring protocol should be quite similar since v13, so maybe you have some chance. Anyway, to confirm the compatibility, you need to test it on your own lab.
Regards,
Dario.
