Roy_Jee
Nov 19, 2019minimum and maximum vlans can be assigned as tagged on a single interface
can anyone tell what are minimum and maximum vlans can be assigned as tagged on a single interface ?
It's depends on device capability. Minimum tagged VLAN is 0 and maximum is 4094 per device. As I know., for more specific info plz connect with support team.
Thanks,
- Roy_Jee
vlan o is reserved i guess so should'nt it be 1 ?
- Rama_gupta
The value of a VLAN tag can be between 1 and 4094.
