How to implement OAuth (authorization code flow) for mobile-apps using deep-links as redirection URL
Hello,
does anyone know why it is currently not possible to configure an OAuth-Client config with Grant-Type 'Authorization Code Flow' and a 'custom-scheme'-redirect URI (mobile app deep-link)?
For example I want to create a "Oauth Authorization Server - Client Application" with Grant-Type 'Authorization Code Flow' and as redirect URI i want to configure "com.mydomain.app://oauth/callback"
Can someone explain why this is not working?
Cheers
dgr84 - thanks for the question. I see you've not had a response - lemme see who I can find.
Have you tried some custom irule as I am not an oauth expert by no means but maybe try configure the redirect as an irule as the example below:
There is also an iRule option to be attached under the OAuth Server but there is not a lot of info for it:
https://community.f5.com/t5/technical-forum/using-custom-oauth-client-irules/td-p/254118
