GalalNabil's avatar
GalalNabil
Dec 21, 2021
Management Interface Traffic
Hello,
how can i use the management interface for application traffic.
  • Hello,
    No you can't. It is not possible to access pools and nodes via the management interface.
    • GalalNabil's avatar
      GalalNabil
      i've already configured the configuration of 1nic on azure, the interface is used for both management and application traffic. i added additional interface on the new configuration and i want to use the management interface for app1 the second interface for app2.
  • Ok, in Azure the setup is different then on hardware. A TMM interface is also used to manage the device.
    Why did you add an extra interface??
      GalalNabil
      i want to add another web server, i tried the sni feature but it didnt work, so i added a new interface but in the network settings the mgmt interface is not shown, so i want to configure it as a traffic interface.
  • You do not need to add an extra interface. On VM level in Azure you need to add a secondary ip address to the NIC. This is the IP address of your second Virtual server.
      GalalNabil
      then i use the SNI ? i tried the SNI before but it didnt work.
