15-Mar-2023 02:43
Hello,
Please can someone help me to find where i can check the reason of making the IP address for one of our partners a malicious IP address categorized under bot and spam classes ? even if the scan of this ip address is clean according to virustotal.
sincerely yours
Solved! Go to Solution.
15-Mar-2023 08:55
Have you tried https://www.brightcloud.com/tools/url-ip-lookup.php yet? If I'm not mistaken, this should be the same database as the F5 uses for its assessment. If it's flagged as bad, it will tell you what for.
Hope this helps.
P.S. You're probably beter off posting these questions in the Technical Forum as you might get a quicker answer.
15-Mar-2023 08:55
Hope this helps.
16-Mar-2023 02:16
Thank you very much
