16-May-2020 06:10
Hello everyone!
I would like to know if anyone has created a security policy base on a vulnerability scanner? In my case, I am reviewing the ASM documentation and I find an option that says: "Security policy integrated with vulnerability assessment tool"
but i have not found much documentation about it and I am interested, I'm trying to do a quick learning for a security policy using OWASP ZAP, but I'm not sure of the results, also I find that there is an option in the ASM where I can download a template for a generic scanner, but I don´t know how to use it.
Could someone give me some links or documentation, or if you have experience can you help me, please!
Thank you very much in advance!
18-May-2020 17:03
You need to do next:
Thanks, Ivan
20-May-2020 07:46
Thanks Ivan,
try to upload the file as generated by ASM but it apparently doesn't work with OWASP ZAP.
Thanks a lot
20-May-2020 12:38
So, you are not able to use xsd schema from ASM in your scanner?
