LTM setup for VMware not working . Could anyone please help troubleshooting this . Its bit urgent please. thanks in advance
LTM setup for VMware not working . Could anyone please help troubleshooting this . Its bit urgent please. thanks in advance.
All configurations done, but VIP is not working
Hi Arun,
Is the VIP green? If not, remove the health monitors from your pools and test it.
- ArunB_330395
Hi Kees,
Thank you for your quick reply.
yes VIP is green. Pool and Pool members are also green.
2 pool members - running with HTTP webserver on port 80. I am able to directly access them from browser.
But from VIP , nothing works!
Could you please help from coming on Skype online.
thanks
- Jad_Tabbara__J1
Hello Arun,
From VS configuration did you add the "Automap" ?
Regards
Hi Arun,
Sorry, I am a bit busy and unable to come online with Skype.
Have you tested with tcpdump on the cli that traffic is arriving at the vip's ip address?
Cheers,
Kees
- ArunB_330395
Hi Kees,
Not sure how to do this testing.
Is this command to be executed on F5 BIGIP device? Can you please send the full command. I will paste the result.
thanks
- ArunB_330395
setting "source address translation" to "automap" also didn't help.
- ArunB_330395
Hi Kees,
Please let me know when you get available for 5 mins. I can share you the screen and show you the problem. Could be its trivial mistake I am doing it. I think it won't take much time for you to fix the issue.
thanks..
It is to be executed on the command line of the BIG-IP. Use putty to connect to the BIG-IP mgmt ip. Login with the root user.
Command is tcpdump -ni any host
Cheers,
Kees
Hi, I won't be available before 6:00 PM CEST
- ArunB_330395
Hi Kees,
thank you for your quick reply. tcmpdump command is showing dump of self ip broadcast messages.
Could you please message me on arunkumar.boralingappa@gmail.com when you get free for a short time (around 5- 10 mins is sufficient for you to find out where the problem is)
I am in IST time (India)
thanks in advance.
