26-Mar-2020 12:32
Need to get historic data in csv, or some kind of text.
I need to do some calculations against the number of visits in each day - as shown in
Statistics >> Moule Stats :Local Traffic >>Pools the [Connections | Total / Pool} number .
Is there a way to pull the historic data from the CLI ?
If only the Total/Member number is available then I can do the math.
As a fall back I can gather and clear periodically, if I could only clear from the CLI - how do I clear the counters from the CLI ?
[harryc@bigipprod05:Active:Changes Pending] ~ # tmsh show ltm node
Ltm::Node: AEMweb01 (192.168.3.91)
Status
Availability : available
State : enabled
Reason : Node address is available
Monitor : /Common/icmp (default node monitor)
Monitor Status : up
Session Status : enabled
Traffic ServerSide General
Bits In 61.1G -
Bits Out 2.7T -
Packets In 40.3M -
Packets Out 57.6M -
Current Connections 25 -
Maximum Connections 178 -
Total Connections 1.4M -
Total Requests - 2.7M
Current Sessions - 0
Ltm::Node: cq5redir03 (192.168.3.51)
Status
