aali86's avatar
aali86
May 03, 2023
LTM policies to remove ASM cookie hijacking for specific IP address
Dear Expert
Could you please assist me with creating LTM policies for removing ASM cooking hijacking for specific IP addresses? It would be great if you could share screenshots?
  • Hi aali86,
    You can use two different waf policies and disable the ASM cookie hijacking in one. If there is an existing waf policy, you can clone the policy and disable ASM cookie hijacking.
    Afterwards, WAF policy is assigned according to IP addresses with LTM policy.
