mikey_webb's avatar
Jun 01, 2021
LTM monitor - help
I have a pool with 2 servers 10.0.0.1 and 10.0.0.2 that runs multiple websites, i'm looking to have multiple monitors attached to the pool one for each url. the below send and receive strings.
Question is the below correct and what is the traffic flow in other works does it check the below url by sending to each server or will it resolve example1.test.co.uk to its external url and test aginst that
GET / HTTP/1.1\r\nHost: example1.test..co.uk\r\nConnection: Close\r\n\r\n
HTTP/1.1 200 OK
any help would be good
