11-Sep-2023 02:55
Hello
My LTM certificate will expire, How can I renew it without repeating it again?
If I take ASM, GTM or APM will renew it!
Solved! Go to Solution.
11-Sep-2023 05:19
Purely to renew the LTM exam, you can take the 301b (Troubleshooting) exam - that should renew your 301 and 201. Taking the DNS, ASM or APM, will NOT renew the LTM. The reasoning behind it, is that the modules are too different from eachother to warrant the renewal (which is quite annoying, but I tend to agree with).
Alternatively, if you pass your DNS exam as well, you can go for the Cloud Architect (402) exam, which will automatically renew the 301 and 302.
In my case, I renew my 401 one year, and the 402 the other, keeping all my 30X exams up-to-date.
Hope this helps.
12-Sep-2023 04:44
11-Sep-2023 03:07
Hi @Ireda,
The renewal of a certificate is a security process that has to be executed to avoid man in the middle or other common attacks regards certificates, if your F5 is local and you want to keep the same certificate for many years, you can renew the certificate internally for 10 or more years, probably in 10 years you have changed your F5 devices.
To renew a certificate go to
System ›› Certificate Management : Device Certificate Management : Device Certificate
click in Renew and for Lifetime ser 3650.
Hope it works
11-Sep-2023 03:41
Thanks for your reply, but i mean F5 exam certification, not F5 certificate
11-Sep-2023 05:19
Hope this helps.
12-Sep-2023 04:44
Thank you for answering, it surely helps me.
