LTM and java certs
I have an internal web app I need to load balance. this app is SSL and I would like to use cookie persistence. I have setup my cert on my LTM and setup persistence before for other apps and it works well. issue I have run across with this new app is that even though the apache cert on the app matches our cert on the LTM, there is a portion of this app that uses java with the companies certificate. this results in the ssl decryption\encryption needed for cookie persistence to break on the java portion making the web app not function all together.
are there any options in this scenario of java cert being different from the web server cert or am I stuck changing my persistence from cookie to ssl?
PS I have an older bigip 1600 with 9.4 running.
