27-Nov-2017 06:03
Hello there
Just a quick query, is there any recommended design guides for LTM & ASM?
I am looking to integrate an ASM inline (performing L7 WAF) in-front of an operational LTM already hosting VIP's. These are separate virtual machines. I understand normally in scenario's the LTM would have the ASM module licensed and therefore you would apply ASM profiles to the LTM VIP's themselves.
Is there anyway to collaborate these modules together even though they exist on different boxes?
Many thanks for your help in advance.
Solved! Go to Solution.
27-Nov-2017 07:00
Please go through this post. Hope it will give some clue.
https://devcentral.f5.com/questions/can-i-put-other-f5-asm-module-in-different-physical-box
There is use case link
(editors note: deployment guides have moved here: https://www.f5.com/services/resources/deployment-guides)
27-Nov-2017 07:00
29-Nov-2017 05:44
Thankyou, much appreciated!
23-Oct-2020 04:04
Hi Samir,
Error 404 in both links....
https://www.f5.com/pdf/deployment-guides/big-ip-ltm-asm-dg.pdf
Could you solve this problem?
23-Oct-2020 10:58 - edited 21-Mar-2022 02:15
- I updated the first link in Samhir's answer.
But deployment guides moved here: https://www.f5.com/services/resources/deployment-guides
and the one above is likely archived in this sub-page: https://www.f5.com/services/resources/deployment-guides/deployment-guide-archive
I can't tell exactly which one you are looking for - if it's possible to identify the one you want there let me know and I'll update Samhir's answer with that one specifically.
