30-Jan-2018 12:35
I am trying to come up with a way to load balance a large amount of syslog messages that are coming from a single node.
I created a stateless VIP. I created a UDP profile with LB datagram and an immediate timeout setting. I have a pool of 2 servers that I want to split between the two nodes evenly on a per packet basis.
Yet all traffic goes to one node.
Am I missing something?
30-Jan-2018 13:56
Have you created a UDP profile with "Datagram LB" enabled?
27-Jan-2023 07:06
Hello,
For me, UDP profile with "Datagram LB" enabled, split between the two nodes evenly, but I do not receive the same quantity of logs!
You encounter this problem?
Thanks!
27-Jan-2023 16:04
Hi @cpt_ri_F5 what ratio of load balancing are you getting?
27-Jan-2023 23:36
Hello, ratio 50% 50%, but 80% of lost logs!
29-Jan-2023 04:07
For reference, discussion pretty much continues here:
https://community.f5.com/t5/technical-forum/udp-datagram-lb/m-p/309048
30-Jan-2023 08:45
@boneyard ah thanks for linking!
