Technical Forum
Custom Alert Banner
load balancing based on hattp clien data
omar_padilla
Altocumulus
Altocumulus
Hello experts, I have a question, is there a way to balance a traffic based on the payload of an http request? For example, inside an http message (not headers) there are some html tags that must be used to determine which pool member to use, is it possible?
2 REPLIES 2
Hello Omar.
It's not the most efficient way to do it, but technically it's possible.
HTTP_REQUEST_DATA occurs before the loadbalancing decision (LB_SELECTED).
REF - https://clouddocs.f5.com/training/community/irules/html/class1/module1/iRuleEventsFlowHTTPS.html
You should use the HTTP::payload method to collect the payload in the HTTP_REQUEST event and then apply your logic inside the HTTP_REQUEST_DATA event.
REF - https://clouddocs.f5.com/api/irules/HTTP__payload.html
Regards,
Dario.
Regards,
Dario.
thank you man!
