13-Oct-2021 11:15
We have 1 read/write node and two Read-only nodes, so we want all the Get http requests to be distributed equally in them and all other requests like POST, Patch, Delete to be forwarded to read/write node
Example :-
Node1 : R/W " it will receives Get , Post,Patch,Delete "
Node2 : Read-only "it will receives Get Requests only "
Node3 : Read-only "it will receives Get Requests only "
Thank you in advance
13-Oct-2021 16:01
Hi Ahmed,
Can you try this iRule?
if { [HTTP::method] ne "GET" } {
node node1ip port
# GET requests are forwarded to the default pool. No need to use else statement.
13-Oct-2021 23:33
Thank you for your reply .
Kindly when i use this iRule that's mean Node1 will not receives GET requests but it can receives " Post, Patch, Delete" requests and F5 BIG-IP will continue Load balance GET Requests to Node2 and Node3 ? Please advice
14-Oct-2021 02:01
Kindly when i try to deploy iRule it shown me an error
14-Oct-2021 03:30
You must add } (closing brace) to row 5.
With this irule, ALL methods will forwarded to node1, only GET requests will forwarded to node2 and node3.
17-Oct-2021 00:08
Thank you i will try it 🙂
