Moustafa_Mamdou's avatar
Moustafa_Mamdou
Jul 22, 2020
LCD panel failure
I have BIG-IP 4000 Series.
The LCD panel under the f5 Network show only option.
and don't show other menus such as; information, or system menus. Also, I tried to log in using the management port with its management IP address but the browser shows only Configuration Utility restarting... for around 30 minutes. I tried to reboot the appliance but without changeing.
  • Can you console and get inside the grub menu and do an EUD. If possible please open a support case, it could be a possible RMA.
