Technical Forum
Custom Alert Banner
LB:detach how it works?
Srikar
Altostratus
Altostratus
Does LB:detach keeps server side connections open for subsequent client requests? Is it similar to Oneconnect profile? Thanks!
1 REPLY 1
I don't think that it keeps them in a pool for reuse it just drtaches them like the OneConnect but without the reuse option. You need Oneconnect for that:
https://support.f5.com/csp/article/K7964
https://clouddocs.f5.com/api/irules/ONECONNECT__detach.html
