JSON Parsing in ASM
Hi All, In the traffic learning, I am observing lot of new Parameter Name learning suggestions as improper or not parsed.
Example- UserID:46w/lSAPnQfkjenA==
Where UserID is the parameter and 46w/lSAPnQfkjenA== encrypted value of the parameter.
Traffic Learning feature should suggest me to add the parameter “UserID” or add and tweak/loosen the policy.
Unfortunately that is not happening, I am getting Traffic Learning suggestions to add the parameter “UserID:46w/lSAPnQfkjenA==“
I can parse the parameters specific to the pre-configured URLs in the Application Security - URLs - Allowed HTTP URLs associated with the JSON content profile.
But I cannot configure all the URLs and associate it with the JSON profile to parse the parameters.
If I associate the JSON profile to the wildcard URL and wildcard parameter, will it be able to get the Traffic Learning suggestions of new parameters as parsed parameter name ?
Please advise, if you have any other recommendations to get the Traffic Learning Parameter name suggestions with proper parsing.
