Jacob_Gilley_28
Mar 02, 2005Java SOAP Binding using Apache Axis
I'm using Apache Axis 1.2 WSDL2Java utility to create Java interfaces from the 4.6.2 WSDLs. However, I'm running into problems with data type mapping during bean (de)serialization. Here is the exception that's being thrown:
Mar 2, 2005 12:41:28 PM org.apache.axis.encoding.ser.BeanPropertyTarget set
SEVERE: Could not convert java.lang.Integer to bean field 'status', type com.f5.icontrol.itcm.globallb.ITCMGlobalLBEnableStatus
Mar 2, 2005 12:41:28 PM org.apache.axis.client.Call invoke
SEVERE: Exception:
java.lang.IllegalArgumentException: argument type mismatch
at org.apache.axis.encoding.ser.BeanPropertyTarget.set(BeanPropertyTarget.java:142)
at org.apache.axis.encoding.DeserializerImpl.valueComplete(DeserializerImpl.java:249)
at org.apache.axis.encoding.DeserializerImpl.endElement(DeserializerImpl.java:509)
at org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:1083)
at org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRecorder.java:171)
at org.apache.axis.message.MessageElement.publishToHandler(MessageElement.java:1140)
at org.apache.axis.message.RPCElement.deserialize(RPCElement.java:347)
at org.apache.axis.message.RPCElement.getParams(RPCElement.java:386)
at org.apache.axis.client.Call.invoke(Call.java:2402)
at org.apache.axis.client.Call.invoke(Call.java:2301)
at org.apache.axis.client.Call.invoke(Call.java:1758)
at com.f5.icontrol.itcm.globallb.ITCMGlobalLBWideipBindingStub.get_wideip_list(ITCMGlobalLBWideipBindingStub.java:1991)
at com.f5.icontrol.Main.main(Main.java:16)
Any suggestions?
Sort By
- Unfortunately, Our WSDL implementation on the 4.x platform is not compatible with Apache Axis. The reason stems from our implementation of enumerated types and that in 4.x we use integers
ENABLE DISABLE DISABLE_PARENT
