Mark_Cloutier's avatar
Mark_Cloutier
May 02, 2010
issues with Failover after upgrade from 9.3 to 9.4.8
I have a pair of 1500s that were running 9.30. I just upgraded them to 9.4.8, and everything seemed to go fine, application testing is going smoothly right now. The only problem is that when I force a unit to standby, I have to do a clear arp on my Cisco L3 switches in order to get traffic to go to the newly active 1500.
  • I have seen this behavior in other versions of the code. The best way to get around this issue is to simply use MAC Masquerading. This is where you define a virtual mac address that is shared.
    You can find more information about how to configure on the following link
    https://support.f5.com/kb/en-us/solutions/public/7000/200/sol7214.html
    I hope this helps,
    Bhattman
