Technical Forum
Issue in Downloading Files (pdf/xls/jpeg) with ASM Policy and http profile enabled
RAHUL0018
Altocumulus
Altocumulus
Hello Everyone,
I have an environment in which I have enabled ASM Policy and is in blocking mode. The HTTP Profile is also enabled.
I am getting 'Failed-Network Error' while downloading files and LTM logs shows me this error
Jan 8 10:53:38 err tmm3[20410]: 011f0016:3: http_process_state_prepend - Invalid action:0x10a010 Server sends too much data. serverside clientside (Server side: vip=/Common/profile=http pool=/Common/)
I have tried so many solutions given on different forums, but could not get through this. Some suggest to disable http and ASM for particular URI, upon doing which, the webpage stops loading.
Kindly help.
3 REPLIES 3
Samir
MVP
MVP
The virtual server is configured with an HTTP profile, and the BIG-IP system receives a response from the pool member that either contains more data than indicated in the Content-Length header or has additional data following the ending chunk of a chunked response.
Article K42151600 may help you to solve issue.
My issue has solved with this article hope yours will be solved..
 . I have applied the iRule, but still, it dint work. Please confirm if applying iRule in your case resolved the issue.
My environments irule worked perfectly. Did you enable some db variable​ and try...
Note- Try to configure setting in non business hour. Follow the process w.r.t company policy.
