26-Sep-2023 14:59 - edited 26-Sep-2023 14:59
Is there a tool within the Big-IP that allows you to trace inbound connection to see which virtual server its being processed by?
Solved! Go to Solution.
27-Sep-2023 06:16
A couple of people have asked very simular questions resently.
Try looking here
Solved: iRule to log traffic details - DevCentral (f5.com)
This page shows how to get the virtual server name
https://community.f5.com/t5/codeshare/example-of-static-variables-with-virtual-server-specific/ta-p/...You may also find these to links useful for HTTP and IP info for the connection.
https://clouddocs.f5.com/api/irules/HTTP.html
https://clouddocs.f5.com/api/irules/IP.html
From the first example, plus the other references you should be able to pull together you want to see and either log this to file or to a remote server.
26-Sep-2023 21:11
@TrainerBob I believe what you're looking for is at the following link.
https://my.f5.com/manage/s/article/K40033505
Once you have this information you should be able to easily tell which virtual server (VS) is being used based on destination IP, port, and protocol.
27-Sep-2023 05:51
This might be the solution. Can you explain what the "Slot" number and TMM instance is? Is this related to a virtual server?
The goal I'm trying to get to is to identify which VS is processing a specific connection. This is for troubleshooting purposes.
27-Sep-2023 02:27
Not to sure what you are trying to find out here.
But you can amend your logging to send logs on a per connection basis and review and filter that using a policy or irule.
Or you could use telemetry or netflow with a suitable collector to filter it down at that level.
Depends on what you are looking for and the tools around you.
The cli option is more real-time but again might tell you want you want to know.
27-Sep-2023 05:53
Will the logs show which VS is processing a specific connection? I'm not seeing anything for my client IP when I grep /var/log/ltm for it. I'm guessing maybe I need to make a change to the log settings to get connections logged or they're in another log?
27-Sep-2023 06:16
Try looking here
