Technical Forum
Is there a way to see http header forwarded to another url ?
jeffrey1984
Cirrus
Cirrus
The request comes into our Apache web server which is configured for Shibboleth and is sent to SSO which validates the credentials and does a POST back to Apache web server which then forwards the request onto another url. Is there a way in F5 LTM to see the HTTP header being forwarded to the new url specially the euid of the user? Thanks in advance
1 ACCEPTED SOLUTION
Andrew-F5
F5 Employee
F5 Employee
Assuming the traffic is either (a) not encrypted or (b) the F5 is decrypting it then yes, using an HTTP profile and iRule or Local Traffic Policy.
See the iRule HTTP::header CloudDocs page for more details.
when HTTP_REQUEST { if { [HTTP::header exists "myHeader"] } { log local0. "The value of myHeader is [HTTP::header value myHeader]" } }
2 REPLIES 2
Andrew-F5
F5 Employee
F5 Employee
Thank you Sir. Appreciate you prompt response .
