Technical Forum
Custom Alert Banner
Is nPath still practical?
kridsana
Cirrocumulus
Cirrocumulus
Hi
We want to use F5 LTM to load balance local DNS server.
We have F5 LTM implement as one-arm topology but we need to preserve source IP for DNS traffic. = No SNAT.
So I check and find that there is DNS load balance with nPath.
But it's a bit old document and I didn't have any experience with it.
Is LTM using nPath deployment to load balance microsoft DNS server  practical?
Kridsana
6 REPLIES 6
kridsana
Cirrocumulus
Cirrocumulus
There is some issue like this post. it's conflict with netbios or something. (not sure if it correct info though)
https://community.f5.com/t5/technical-forum/has-npath-routing-caused-any-problems/td-p/151743
Hi @kridsana,
The easiest way to deploy this config is to make the Float IP of your F5 the default gateway for your DNS servers and create a Forwarding VS 0.0.0.0/0.0.0.0 to give internet access to DNS servers through your F5.
Npath configuration can disturb the sync cookie protection feature in the LTM so if you can avoid it I really recommend it.
Hope it helps.
Hi
I've some questions.   In my case, DNS server default gateway is not F5 LTM
1. Do we need to create Forwarding VS for DNS server for outbound traffic?
2. If we using F5 for DNS udp 53 (nevermind TCP 53 for zone transfer), sync cookie protection can be ignore, right? I understand that sync cookie is for TCP only.
3. There is no problem to use nPath, Am I correct?
Just remember DNS is/can be UDP and TCP which unless i've forgotten a config is two sperate Virtual Servers. One for UDP and one for TCP.
So we just have to create 2 virtual server (  UDP 53 for DNS query/response  and TCP 53 for zone transfer)
Am I correct?
yes - you can use nPath
