SSHSSH_97332
Mar 23, 2012Nimbostratus
Irules Question
i have Vs & 2 Pools , i need to forward to one Pool based on source Ip like the below :
If Src ip =x , Forward to Pool1
if not Forward to Pool2
The question is :
Can i do the below :
Irule Logic : if srx-ip=x forward to Pool1 + use Def Pool under Vs as Pool2 , by that if something didnot match the condition of src-ip =x will Vs go back to use default pool or it will drop the packet ?
( or it is mandatory to use it at the Irule like : if src-ip =x Forward to Pool1 , if not forward to Pool2 , all in the Irule without depending on default Pool at VS ? )
