Technical Forum
Irules memory consumption 14.1.4.6
SEJ
Hello Team,
Does anyone know how to display the irules memory consumption?
Thanks, Salah
2 REPLIES 2
Samir
MVP
MVP
Basic CPU/Memory/execute cycle consumption you can view via irule command. Some of the old thred is here
https://community.f5.com/t5/technical-forum/irules-performance-measuring/td-p/221629
tmsh show ltm rule irule_name
However you wanted to decode entire memory cycle then its not possible by end user prospective but still you can decode tmm, swap memory, etc. Hope above thred can help you.
LiefZimmerman
Community Manager
Community Manager
@SEJ - If your post was solved it would be helpful to the community to select *Accept As Solution*.
This helps future readers find answers more quickly and confirms the efforts of those who helped.
Thanks for being part of our community.
Lief
