Zev's avatar
Zev
Mar 16, 2020
iRules fail in v14.1.2.3
I recently upgraded from v12.x to v14.1.2.3 and simple redirect/rewrite iRules seem to fail. At first I removed the iRule, deleted it and just recreated it and this worked for a bit (2nd rule below)! However, it suddenly fails and I cannot tell why this would happen. I have seen a number of similar threads but nothing really answers the issues.
I have one irule that contains:
    switch [string tolower [HTTP::host]] {
       "support1.xyz.com" {
          # port 7080
          log local0.
          pool SupportPool
       "support2.xyz.com" {
            # port 7080
          log local0.
          pool SupportPool
And another that contains:
            if { [HTTP::uri] equals "/" } { HTTP::redirect "/portal/ss/?guest=0"}
            switch -glob [string tolower [HTTP::uri]] {
                "/" { HTTP::redirect "/portal/ss"  }
                "/support" { HTTP::redirect "/portal" }
                "/downloads" { HTTP::redirect "https://ftpdl.xyz.com" }
I've read maybe these are now in conflict with how v14.x looks at iRules? Regardless, this worked flawlessly up until now. I cannot make sense of it as the syntax is correct! Now if any of the URIs are typed it returns a PR_CONNECT_RESET_ERROR error in browser as if the pool or iRule doesn't exist. Is there a new way to express this or new syntax?
    • Zev's avatar
      Zev
      SB,
      Thanks, this is the most direct answer I have found. I am not exactly sure how I would integrate HTTP::has_responded in to this 2nd iRule as I need the rewrites to function/take precedence. It seems the order is different as well. I was just beginning to understand iRules in v12 now I am a little lost again.
      • First - always use priority statements to control event execution order if you are using multiple irules with the same event.
        Second, at the start of the earliest executing event, set variables that contain the things you might need in later irule events (HTTP::host, HTTP::uri, HTTP::path, etc). Then refer to the variables rather than the HTTP:: functions.
        Use the following code fragment after a HTTP::redirect/HTTP::respond
            HTTP::redirect "<location>"
            event disable
            return
  • VB's avatar
    VB
    Hi Zev Hi Simon,
    We have the same issue with a very large and old irule using a switch.
    We tried and tried but do not seem to find the correct syntax to make the irule work.
    Does one if you have an example for using the HTTP::has_responded function within a switch?
    (and yes we are already planning a move to using LTM policies but with multiple irules on a VS its not that easy)
    • Use the following patterns from K23237429 everywhere:
         if {[HTTP::has_responded]}{return}
      and
          event disable
          return
    • Zev's avatar
      Zev
      Yes, Simon is correct here and I found that the 'event disable' is a critical piece! This is the only helpful answer. Literally everyone will advise to use HTTP::has_responded, even F5 LTM support and Reddit, but you must complete the pattern with event disable. Follow this syntax; I've had no more issue.
