irule with two subsets of sideband connection - one works fine the other failed
Hello forum,
I have an irule that contains 2 subset of of sideband connection procedure, origianlly replaced http authentication which does not work in route domain enviroment (works only in common route domain).
The 1st sideband connection (called sms_session" ) is used to send OTP to end user via sms broker - thats works fine.
The 2nd sideband connection (called enc_id" ) is used for sending encrypted username for autherization service - that's fails.
Both works in route domain 5 in my Viprion configuration.
The error that i get in CLI is as follows:
"Aug 4 19:26:35 slot3/vip_bareket err tmm3[13801]: 01220001:3: TCL error: /REMOTE.KISHURIM/fixed_mnbs_rule - Command must start with connect.invalid connection handle (line 1) invoked from within "connect info -idle -status $conn" ("enc_id" arm line 14) invoked from within "switch -glob [ACCESS::policy agent_id] { "otp" { set otppw [string r...""
Any Idea - why it works for one and not for other.
Regards,
Yossi Mor
