17-Oct-2018
12:44
- last edited on
02-Jun-2023
08:12
by
JimmyPackets
Hello
We actually use an IRule to manage different API in my organization.
For maintaining purposes, it would be simpler to use an LTM Policy instead. I have tried to configure an LTM Policy to do the equivalent of my IRule, but it doesn't seem to be working.
IRule:
switch -glob [string tolower [HTTP::uri]] {
"/service1/feature1/*" {
Client request: https://mywebsite.com/service1/feature1/*
Server request: http://servername:12345/api/*
HTTP::path [string map -nocase {"/service1/feature1/" "/api/"} [HTTP::path]]
pool service1_feature1_pool
LTM Policy equivalent:
Match all of the following conditions:
[HTTP URI][path][begins with] any of [/service1/feature1/]
Do the following when the traffic is matched:
[Replace][http uri][path][/service1/feature1/] with value [/api/]
[Forward traffic] to [pool][service1_feature1_pool]
The [Forward traffic] part works well with the LTM Policy. But when I add the [Replace] line, it doesn't seem to replace the [Path] in the way I want to do the server side request.
Am I doing something wrong ? Is there a known issue with the [Replace] command in LTM Policies ?
Thanks for your help!
