iRule to remove Headers which have whitespaces
InderS
Hi all,
I have an HTTP response which has a few headers like these:
<process name:sample den
<process type:bikole
<pragma:i224242
I am trying to write an iRule to remove these headers - "process name" & "process type".
Here are iRules I tried, but none of them work. Interestingly both of them work on "pragma" ( because there is no whitespace in the header name):
iRule#1
when HTTP_RESPONSE {
   HTTP::header remove "process name"
   HTTP::header remove "process type"
HTTP::header remove "pragma"
OUTPUT: pragma removed but "process name" & "process type" still there
iRule#2
 foreach aheader [HTTP::header names] {
   log local0. "Header Name: $aheader"
   if { $aheader contains "process" } {
     log local0. "Header Removed: $aheader"
     HTTP::header remove $aheader
OUTPUT: "process name" & "process type" were not removed.
loggers:
Header Name: process
Header Removed: process
Header Name: name
Header Removed: name
Header Name: type
Header Removed: type
Need urgent help to remove these pls. Can someone help?
4 REPLIES 4
Simon_Blakely
F5 Employee
F5 Employee
That's going to be difficult using HTTP::Header, because with that space in them, they are not technically headers within the RFC specification. This confuses the HTTP parser, so the irule does not work.
Your best approach is to use TCP::collect and the SERVER_DATA event, and a stream match to replace or remove part of the TCP payload from the pool member.
Thanks for your prompt reply. Can you please help with some samples?
This irule uses TCP::collect and TCP::payload to change the header names to ones without a space so they can be deleted:
when HTTP_RESPONSE { HTTP::header remove "process_name" HTTP::header remove "process_type" HTTP::header remove "pragma" }   when SERVER_CONNECTED { TCP::collect } when SERVER_DATA { log local0. "in SERVER_DATA [TCP::payload]"   set header_1 [regexp -all -inline -indices {process name} [TCP::payload]] set header_1_start [lindex [lindex $header_1 0] 0] set header_1_end [lindex [lindex $header_1 0] 1] set header_1_length [expr ($header_1_end - $header_1_start) + 1] log local0. "process name occurs at byte $header_1_start, length $header_1_length" TCP::payload replace $header_1_start $header_1_length {process_name}   set header_2 [regexp -all -inline -indices {process type} [TCP::payload]] set header_2_start [lindex [lindex $header_2 0] 0] set header_2_end [lindex [lindex $header_2 0] 1] set header_2_length [expr ($header_2_end - $header_2_start) + 1] log local0. "process type occurs at byte $header_2_start, length $header_2_length" TCP::payload replace $header_2_start $header_2_length {process_type}   TCP::release }
It could be written in a more efficient way, but this hopefully makes it clear at each step what is happening. You should also only collect enough SERVER_DATA to get the headers that you want to manipulate, rather than collecting the entire TCP response which could be expensive on memory.
J_McInnes
F5 Employee
F5 Employee
Have a look at the stream profile, its probably the simplest way to do what you want
