Technical Forum
iRule to modify response code for ASM blocking page
ebrc
Hello everyone,
I would love to receive your help to create an irule allowing me to modify the response code (with a 500) of the blocking page of ASM when an illegal request is matched.
The goal is not to modify the global response page that's why I want to do it in an irule so that this behavior happen only for on VS and not the other (which all use the same ASM policy).
Thank you very much in advance!
6 REPLIES 6
Hi ebrc,
Can you try this iRule?
	set asmstatus "allowed"
when ASM_REQUEST_BLOCKING {
	set asmstatus "blocked"
when HTTP_RESPONSE_RELEASE {
	# log local0. "ASM Status: $asmstatus"
	if { $asmstatus equals "blocked" } {
		HTTP::respond 500 content {
			<html>
			<head>
				<title>Lorem ipsum</title>
			</head>
			<body>
				Lorem ipsum dolor sit amet, consectetur adipiscing elit. Phasellus non metus mauris.
			</body>
			</html>
Thank you very much eaa!
As I see, in your irule, the blocking page is completely replaced.
My challenge is to keep the blocking page exactly as it is in ASM POlicy but just to replace the response code by 500.
iFile (asm_custom_response):
<html>
<head>
    <title>Request Rejected</title>
</head>
<body>
    The requested URL was rejected. Please consult with your administrator.<br><br>
    Your support ID is: $supportid <br><br><a href='javascript:history.back();'>[Go Back]</a>
</body>
</html>
iRule:
	set supportid [ASM::support_id]
	# log local0. "ASM Status = $asmstatus"
		# log local0. "Support ID = $supportid"
		HTTP::respond 500 content [subst -nocommands -nobackslashes [ifile get asm_custom_response]]
Thank you eaa!
I will try and give feedback then.
There is no way to just keep the ASM blocking page from ASM policy (that we already replaced by the customer's one) and just replace the error code?
I think your way will work, but we will have to maintain the same blocking page in 2 different places (ASM + ifile)
gersbah
    set blocked 1
    set response [ASM::payload]
    catch {
        if { $blocked } {
            HTTP::respond 500 content $response
Something like this should work. The "catch" to prevent errors for not-blocked requests may be a bit crude. The thing eaa did with setting the indicator for all requests may be better. But this is shorter. I don't know, I'm not a programmer.
ebrc
Thanks guys for all your answers!
I really appreciate it. I'm waiting the customer now to schedule the different test.
I will let you know (but it may take some time).
