Juan_Carlos_Rom's avatar
Juan_Carlos_Rom
3 years ago
Solved
irule replace and modify uri and response
Hello everyone,
I have a problem with the irule that I've develop to the response from the server.
To put them in context the user access to the app with three different uri:
1. https://example.com/ris1
2.https://example.com/ris2
3.https://example.com/ris3
There are three different pools with two pool members for each.
When the servers receives the resquests is more like:
first sever http://example.com/Novaris with the same name for the path.
My irule is like this:
STREAM::disable
# Check the requested path (set to lowercase)
# -glob: allow string pattern matching
switch -glob -- [string tolower [HTTP::uri]] {
"/ris1" {
log local0. "Matched pool 1 paths for [HTTP::uri]"
set uri [ string map -nocase { "/ris1" "/Novaris"} [HTTP::uri] ]
HTTP::uri $uri
HTTP::header remove "Accept-Encoding"
pool P1
"/ris2" {
set uri [ string map -nocase { "/ris2" "/Novaris"} [HTTP::uri] ]
HTTP::uri $uri
pool P2
"/ris3" {
set uri [ string map -nocase { "/ris3" "/Novaris"} [HTTP::uri] ]
HTTP::uri $uri
pool P3
default {
log local0. "Hit default for [HTTP::uri]"
persist cookie insert "Redimed"
pool Pool_demobank
when HTTP_RESPONSE {
STREAM::disable
if {([HTTP::status] == 200) && ([HTTP::header value Content-Type] contains "text") } {
STREAM::expression { @http@https@ @/Novaris@/ris1@ @/Novaris@/ris2@ @/Novaris@/ris3@ }
STREAM::enable
My problem is in the response.
When the server response because the payload don't show the image so I fix with the stream:expression but with the other two not. Because the path have the same name there is another way to map this problem o I need to explain to the development team to modify the name of the path with each pool.
Thank you if anyone can help me.
  • If I understand you correctly, you need to alter the stream expression in your HTTP_RESPONSE event, based either on the pool that was selected or the URI you received, during the HTTP_REQUEST event.
    Note that you may need to capture that in a variable in the HTTP_REQUEST event, and check the variable in the HTTP_RESPONSE event, because you might only be able to use certain API functions inside certain events.
    Something like:
    set orig_uri [HTTP::uri]
    # the rest of your logic
    STREAM::disable
    switch -glob -- [string tolower $orig_uri] {
    "/ris1*" {
    STREAM::expression {@http:@https:@ @/[Nn]ovaris@/ris1@}
    "/ris2*" {
    STREAM::expression {@http:@https:@ @/[Nn]ovaris@/ris2@}
    "/ris3*" {
    STREAM::expression {@http:@https:@ @/[Nn]ovaris@/ris3@}
     STREAM::enable
    (There are other optimisations that might shorten this, but you should get the gist)
    Note that I have also changed the expression for your http/https rewrite to http:/https: (note the colon), so that any https:// URI returned by the downstream server is not rewritten to httpss://.
    You may also need to handle a case-sensitive response back from the downstream server (I presume you would need to rewrite /Novaris or /novaris for instance).  To that end, you may need to make your stream search expression something like...
    @/[Nn][Oo][Vv][Aa][Rr][Ii][Ss]@/ris1@
    ...so it handles upper- and lower-case.
  • Hi,
    If the stream expression string starts or ends with space, it won't work.
    It looks neater with space, but it shouldn't. 🙂
    # This will work
    STREAM::expression {@IE@Apache@ @Windows@Linux@}
    # and this will work
    STREAM::expression [list "@IE@Apache" "@Windows@Linux@"]
    # but this will NOT work-- notice the space between the '{' and the '@'
    STREAM::expression { @IE@Apache@ @Windows@Linux@ }
    REF: https://clouddocs.f5.com/api/irules/STREAM__expression.html
  • Hi Juan_Carlos_Rom , are you using a OneConnect profile (to be assigned in the virtual server acceleration settings)?
    As you are trying to "demultiplex" requests coming in through a clientside KeepAlive connection, it will be necessary to use OneConnect. Otherwise the incoming connection will be balanced to a pool according to your iRule logic and just stick there. With OneConnect enabled each incoming request will be handled individually.
    I recommend to use a new OneConnect profile with a host mask of 32 bits (IPv4) or 128 bits (IPv6).
    • Juan_Carlos_Rom's avatar
      Juan_Carlos_Rom
      Hi Stephan,
      In this momento in the virtual server, I don't apply any acceleration settings.
      Tomorrow, I'm going to test again with the profile oneConnect with the mask of 32 bits for ipv4.
      Then, I will replay the outcome.
      And thank you,  for your suggestion.
    Something like:
    STREAM::disable
    "/ris1*" {
    "/ris2*" {
    "/ris3*" {
     STREAM::enable
  • Hi,
    # This will work
    • candc's avatar
      candc
      Icon for Cirrus rankCirrus
      Great point -- I have updated my example above.
      I do love TCL but, coming form other languages, their decision to use braces as a string-literal delimeter always catches me out!
