Technical Forum
Custom Alert Banner
irule subtable learning problem
Wangzixuan_3147
hello,everyone: I am learning irule,Found this statement is not very clear, please help me explain it, thank you
when CLIENT_ACCEPTED {
    set tbl "connlimit:[IP::client_addr]"
    set key "[TCP::client_port]"
    if { [table keys -subtable $tbl -count] > 1000 } {
        event CLIENT_CLOSED disable
        reject
        table set -subtable $tbl $key "ignored" 180
        set timer [after 60000 -periodic { table lookup -subtable $tbl $key }]
when CLIENT_CLOSED {
    after cancel $timer
    table delete -subtable $tbl $key
1 ACCEPTED SOLUTION
AMiles_377865
Cirrocumulus
Cirrocumulus
Hello Wang,
I'll try to break down each of the parts of the code that you have question marks next to.
This creates a timer for a command, telling it to repeat every 60000 milliseconds. The command that will be repeated every 60000 milliseconds is:
This command checks the $tbl subtable (a subtable created at the beginning of the Irule that equals the source IP address). The value will be "ignore." Since it is being referenced every 60 seconds, and the default timeout for a table entry is 180 seconds, the cache is prevented from deleting the table value. This line is being used to create a pseudo keep-alive for that entry in the subtable by referencing it every 60000 milliseconds.
    after cancel $timer
This event happens when the client closes a connection. "after cancel" is a command that stops a timer from running, in this case the timer
is stopped. The entry in the subtable is then deleted when the timer runs out.
Feel free to ask if you have any follow-up questions,
Austin
1 REPLY 1
AMiles_377865
Cirrocumulus
Cirrocumulus
Hello Wang,
    after cancel $timer
Austin
