Technical Forum
iRule redirect causing Connection Reset
BrandenL
Hello.
We have a straightforward iRule that will produce a maintenance page if the iRule is added to the Virtual Server. This has worked fine for years - until we updated to 15.1.5.1 (from 15.1.5.0). Now, instead of the maintenance page, the browser produces a Connection Reset error. Here is the iRule:
       HTTP::respond 200 content \
"<html><head><title>Maintenance page</title></head><body></HEAD>\
<p><h2>This site is down for planned maintenance.<br><br>If you need further assistance, please contact the Service Desk.</h2></p></body></html>" "Content-Type" "text/html"
We believe the problem has something to do with the 'content' flag on the HTTP::respond. If we remove the content, we do not get a connection reset. But then we do not get the maintenance page either, so that's no good.
Does anyone have any idea why we'd suddenly be getting Connection Reset errors in the browser?
Thank you!
6 REPLIES 6
djtms
I use full this Template and it work great (with the rule allowing access from VPN)
if { not ( ([IP::addr [IP::client_addr] equals 192.168.1.10]) or ([IP::addr [IP::client_addr] equals 172.10.10.100])) } {
HTTP::respond 500 content {
<!DOCTYPE html>
<html>
<head>
<title>Error Page</title>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1">
<!-- Libs CSS -->
<link type="text/css" media="all" href="//cdn.domain.com/assets/bootstrap/css/bootstrap.min.css" rel="stylesheet">
<!-- Template CSS -->
<link type="text/css" media="all" href="//cdn.domain.com/assets/css/style.css" rel="stylesheet">
<!-- Responsive CSS -->
<!-- Favicons -->
<!-- Google Fonts -->
<link href="https://fonts.googleapis.com/css?family=Open+Sans&amp;subset=latin-ext,latin" rel="stylesheet" type="text/css">
</head>
<body>
<div class="container">
<div class="col-xs-12 col-sm-7 col-lg-7">
<!-- Info -->
<div class="info">
<h2>INFO</h2>
<p>INFO2 <br />THANKS<br /><br /> Company.<br />
</p>
</div>
<!-- end Info -->
</div>
<div class="col-xs-12 col-sm-5 col-lg-5 text-center">
<!-- Img_gif -->
<div class="img_gif">
<img src="//url.com/assets/img/500.gif" alt="500">
</div>
<!-- end Img gif -->
</div>
</div>
<!-- end container -->
</body>
</html>
} Cache-Control No-Cache Pragma No-Cache
BrandenL
Thank you for the response.
Unfortunately, we're experiencing this error any time we use the HTTP::respond method.
Alexandre
Altocumulus
Altocumulus
You should try add code to prevent previous exiting
if { [HTTP::has_responded] } { return };
https://support.f5.com/csp/article/K23237429
Alexandre,
Thank you for the response. Unfortunately, we had tried that earlier and it did not fix the problem.
boneyard
MVP
MVP
the one from Alexandre could very well be it, else do you see something in the /var/log/ltm about it?
that is weird, next step would be more in depth trouble shooting and that is difficult via a site like this. if you have a support contract i would certainly reach out to F5 support, they can look with you at the system.
else you could have a go at enable reset cause and see if a hint pops up there.
https://support.f5.com/csp/article/K13223
