jackwik_134864's avatar
jackwik_134864
Nov 29, 2017
Irule Redirect and cookie inser not working as expected
I am trying to achieve the following:
1). Cookie Insert 2). Define the domain name 3). When redirecting using the original cookie that was received before redirection took place.
IRULE is as follows
when HTTP_RESPONSE {
Check if the persistence cookie exists in the response if {[HTTP::cookie exists "Mobile"]} { set the domain attribute on the persistence cookie HTTP::cookie domain "Test" ".888sport.com" if { [HTTP::is_redirect] } { foreach aCookieName [HTTP::cookie names] { set currentCookie "$aCookieName=[HTTP::cookie value $aCookieName]" set cookies "$cookies\r\nSet-Cookie: $currentCookie" }
Attached screenshot. Any suggestions/help much appreciated.
Thanks.
Jack.
