Technical Forum
iRule Query String Match and Redirect
D_T
Cirrus
Cirrus
I seem to be having difficulty finding too much on this and maybe it is as simple as it is, I am looking to perform a URI match with a few particular query strings and redirect to another website if the request is found. I have found a few articles indicating using a datagroup but this seems a bit excessive for the task I am looking at.
Example:
https://www.thedomain.com/dir1/index.html?newpath=Name1 -> https://www.newdomain.com/dir1/index.html?newpath=Name1
Is this as simple as something like:
   if { ( [string tolower [HTTP::host]] equals "www.thedomain.com"
) and ( [string tolower [HTTP::uri]] ends_with "Name1" ) } {
       HTTP::redirect "http://www.newdomain.com[HTTP::uri]"
Will the query string after the "?" be picked up and carried over with [HTTP::uri]?
3 REPLIES 3
D_T
Cirrus
Cirrus
Or even simpler
When HTTP_REQUEST {
    if{ [HTTP::uri] contains “*?newpath=Name1" } {HTTP::redirect "https://www.newdomain.com/dir1/index.html?newpath=Name1 } }
D_T
Cirrus
Cirrus
Anyone on this?
You need to just play with F5 as many questions can be answered just by playing around. For this maybe  see:
https://clouddocs.f5.com/api/irules/HTTP__query.html
https://clouddocs.f5.com/api/irules/URI__query.html
With HTTP:Respond you may use a different temporary redirect code etc.:
https://clouddocs.f5.com/api/irules/HTTP__redirect.html
