30-Jul-2020 08:31
Below is my current irule, which sends all requests with "/up/*" in the path to the faweb pool, otherwise, requests are sent to the default web pool.
switch -glob [string tolower [HTTP::path]] {
"/up/*" { pool faweb }
default { pool web }
I am looking to modify the rule so that only specific hosts with "/up/*" in the path will go straight to the default web pool.
Example;
https://host1.website.com/up/foo.txt
https://host2.website.com/up/bar.txt
https://host3.website.com/up/dog.txt
should all go directly to default web pool
AND
https://host7.website.com/up/apple.txt
https://host8.website.com/up/orange.txt
https://host9.website.com/up/banana.txt
and any other hose not listed in the first list above (host1, host2, host3)
should all go to the faweb pool
Solved! Go to Solution.
02-Aug-2020 15:13
Hi JQB,
switch [string tolower [HTTP::host]] {
"host1.website.com" -
"host2.website.com" -
"host3.website.com" { pool web }
default {
02-Aug-2020 15:13
Hi JQB,
default {
23-Sep-2020 07:43
Worked like a charm. Thank you.
